Heat exchanger - crazy temperature
I want to simulate heat exchanger. Model pipe in pipe. I want to air flowing with 40°C in inside pipe and air 900°C i outside pipe. What i get is... weird. http://pics.tinypic.pl/i/00547/6mysparxr4p0.png I don't know where the problem could be. Those are setting i made: -Model: Energy On, Viscous Laminar -Cell Zone Conditions: Materials inside pipes air, materials of pipes solid aluminium -Boundary Conditions: inlets of hot/cold pipes are set up on massflow inlet, 0.01kg/s and 900°C/40°C temperature oulets are set up to outflow I am learning fluent for 2 months and maybe i am doing something stupid (and simple i hope so). Yours faithfully, Dawid Pogorzelski |
At first, i think it could probably be mesh-related, your mesh seems course. What are the dimensions of your problem? The residuals have reached convergence? You could give us a little sketch. Check also again your BC, it is a good practice.
Regards |
Hello, thank You for reply. I have changed mesh size. Now elements are much smaller. Unfortunately it didn't change anything. This is 2D problem. I think residuals have reached convergence. What kind of sketch do you mean? Project? I have checked my BC many many times :(
here is link to my project project It is created in asnys workbench 14. I hope together we will find solution :) |
I meant a simple drawing with your bounday conditions and how you have set them up in Fluent.
pd: Also post here your residuals and the result of the new mesh |
ok, i am not sure but i have found reason. It could be velocity inlet sot up i diffrent direction than normal to boundries. So far is good. I hope nothing more will get crazy from now. Thank you for your patience and help :)
Hello again,
After little succes in 2D simulation(based on your help) I decided to create 3D simulation. And again i have strange temperatures. Before (it's shame, i know) the problem was boundary conditions (direction of specification method wasn't normal to boundry). Now i have different problem. In "hot entry" i have great 1013K and in "cold" entry i have beatiful 313K. The problem is that i have 4,83e3K in couple points on "out" wall, and somewhere -14K. I did this time everything as in 2D simulation. I hope it's some stupid and easy mistake but i don't know where to look for it. Please help? Here are: -main problem, weird temperatres on surface of inside pipe: https://imagizer.imageshack.us/v2/63...901/D0oWjy.jpg -mesh (with highlighted inner pipe) https://imagizer.imageshack.us/v2/89...661/t2yJCu.jpg -residuals (first 100 are for laminar viscous model, after is standard k-e) https://imagizer.imageshack.us/v2/13...540/oDCQWV.jpg -my boundary conditions https://imagizer.imageshack.us/v2/11...674/jbZyRV.png |
Hi, it's clear from the residual image that solution is not converged.
Why don't you setup a structured hexa mesh? It is quite simple for your geometry. |
Are you going with steady solver?
You should use unsteady solver when handling heat transfer problem |
