How to measure mass flow rate through slot/surface in 3D |
July 5, 2014, 06:12 |
bluemist
Dear all,
I'm simulating the flat plate flow with slot for suction and blowing in 3D , which mean the slot is a rectangular surface when looking from the top. How do I measure the mass flow rate through the slot? For 2D case, I defined the slot as the interior boundary and use the plot/fluxes to get the mass flow rate. For 3D, I'm trying to do the same as 2D but FLUENT read the slot as the wall-BC which make me to remove the slot surface to model the cavity. or is there any better way recommend me please? I am only need the negative mass flow rate through the slot, ex. -0.02 kg/s and I'm currently using the velocity inlet+negative velocity. thank very much you for your reply, |
Mass Flow rate in spray water modeling | Behnam Ghadimi | Main CFD Forum | 0 | June 8, 2013 15:48 |
Problem with changing mass flow rate | roo | FLUENT | 3 | June 4, 2013 14:53 |
Mass flow rate | sepidecent | CFX | 0 | August 9, 2011 00:15 |
negative global mass flow rate | Gimli | FLUENT | 0 | April 21, 2006 07:17 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
