Problem with boundary conditions
Like Tree2Likes
  • 1 Post By A CFD free user
  • 1 Post By Alber
Old   July 6, 2014, 16:02
Default Problem with boundary conditions
Alber is on a distinguished road
Hello, I am trying to analyze the flow through a catalyst. I do the mesh the interior volume separating the inlet pipe, the catalyst volume, and the outlet pipe.
The problem is when I pass it to Fluent, since in "Boundary Conditions", the contact surfaces are considered as 'wall', instead of 'interior'.
When ANSYS does the mesh, it creates two contact surfaces, but I supose it isn't enough.
How can I solve this?
Thank you very much!
Alber is offline   Reply With Quote
Old   July 6, 2014, 18:04
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
OK pal,
It seems that there are more than one surface in the mentioned place (it may two surfaces overlap on each other), so you can't distinct them easily. It's a very common mistake during model design which comes from wrong usage of split tool. I had the same problem many times and I resolved it with making some effort.
I hope it helps
dreamz likes this.
Regard yours
A CFD free user is offline   Reply With Quote
Old   July 7, 2014, 06:11
Thank you very much for your reply.
I have found the problem. I must enable 'Assembly Meshing' in the 'Mesh Details'. The mesh hadn't continuity, so Fluent considered them as wall, that is to say, different objects.
Problem solved!!
Kind regards!!
dreamz likes this.
Implementation of boundary conditions for FVM Tom Main CFD Forum 7 August 26, 2014 06:58
Problem with Periodic Boundary Conditions Help!!! otsigun FLUENT 0 July 11, 2013 04:20
Boundary Conditions problem o_mars_2010 Main CFD Forum 2 July 8, 2013 03:10
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Problem with Boundary conditions Mahiboobswamulu Main CFD Forum 10 August 26, 2003 14:24
