January 9, 2020, 14:11 |
Export profile files
Hannah Northrup
Rep Power: 6 |
Is there a way to export the profile files used as boundary conditions from a .cas file? I have the .cas file and when I open it up I can see that there are profile files that were uploaded and attached. I want to be able to see the numbers from those files. (I want to check that the correct boundary conditions/profile files were used for the simulation).
Thanks! |
January 9, 2020, 18:34 |
Lucky
Rep Power: 65 |
You should be able to file=>export=>profile and write the PROFILE. The .prof file is just a text file that you can open with any txt editor.
Alternatively, you can also write the solution data on that boundary into an ascii file. The format will be a little different. |
January 10, 2020, 11:32 |
Hannah Northrup
Rep Power: 6 |
Thanks for your help. For anyone else wanting to do this I'll write what worked for me. I was unable to extract the profile file using the first method. When I go to file=>export there is not an option for profile.
I was able to extract data using the second method but the data was not matching up. I must have been looking at something wrong, I am fairly new at CFD. However your methods got me thinking and I was able to figure it out. In the outline view I clicked on Boundary Conditions=>Profiles...=>Write...=>Write... and I was able to save the profile file. When I opened up the file it was almost in the same format as the original. Thanks! |
boundaries condition, boundary condition, profile data, profile data bc, profile files |
export files every timestep or iteration for a convergence-analysis | Muchanical | FLUENT | 0 | November 27, 2019 05:09 |
[OpenFOAM.org] Can't find files when install OF2.1.1 on Mac | hewei | OpenFOAM Installation | 10 | June 3, 2016 06:50 |
Naming export files in Workbench scripts | evan247 | CFX | 1 | January 22, 2015 20:23 |
Question Regarding to Export and Import The Velocity Profile | John Lee | STAR-CCM+ | 4 | September 19, 2014 09:01 |
OpenFOAM gcc configuration problem | preacher | OpenFOAM Installation | 7 | March 3, 2014 22:44 |
