August 19, 2014, 13:32 |
Modeling air flow in Al2O3 melt problem
Tsaba Nagy
Rep Power: 14 |
Dear everyone!
I need to model the flow of air and molten oxide in an Al2O3-melting furnace. The gas is pushed into the melt on 3.2 bars (in a 6 mm diameter tube) using an "oxidizing pike" which is quite thick compared to the tube. The melt volume is much higher than the oxidizing tube. The tube is nearly vertical (~12 degrees from vertical) and the gravity's direction is nearly opposite with the gas flow. As I think, a thinner stream or chanel of air should appear first and farer from the tube, the stream should form into bubbles. Unfortunatley it does not happen. A huge bubble appears in front of the tube and later the melt is pushed out from the furnace. What should be the solution? The melt is quite viscous (0,04 Pa.s). I turned on surface tension modeling too with constant surface tension. The air comes in thru a pressure-inlet. There is a pressure-outlet with zero pressure to simulate an open surface. The model is steady with Eulerian multiphase. Please help. Thanks |
bubble, eulerian, melt |
problem with two phase flow (air injected in water) | miles_davis | OpenFOAM | 15 | March 31, 2021 09:36 |
Data Center Air conditioning Boundary Condition problem | jaypatel | OpenFOAM | 9 | April 8, 2020 15:04 |
Modeling the air flow of an Internal Combustion Engine | mateusdias89 | CFX | 21 | September 23, 2015 08:22 |
Duct air flow modeling | Dan SW FL | Main CFD Forum | 2 | July 6, 2010 04:57 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
