July 25, 2014, 11:01 |
simulating suspension in Fluent
Mahdi Tavana
I'm trying to simulate the mixing case in Fluent.
it consist of two phase.one of them is fluid and another is solid(granular). I need to detect mixing index of mixture( The amount of granular in fluid at the every point of volume) The volume is a cylindrical case with the rotating shaft and blade) I use from mixture model in fluent, but I don't know that how to define mixing index to get the result. Anyone have any advice or a tutorial they could refer me to? Thanks |
fluent, mixing fluid, suspension flow |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Fluent capabilities in simulating turbomachies | CosmicRay | FLUENT | 0 | May 25, 2011 13:47 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
Simulating a Göttingen type wind tunnel in FLUENT | Chris | FLUENT | 3 | December 4, 2006 17:33 |
