Export and import vector data
Old   July 29, 2014, 08:25
Default Export and import vector data
Marcelo Costa
mcribas is on a distinguished road
I have a question regarding the use of Fluent. I have a system of infinite 3D cells, but as you can imagine, the simulation of the whole volume is impossible. Another problem is that the system is unstable, so unsteady state simulations are required.
What i want to do is basically simulate more than one cell, without changing the mesh. So the idea was to use the results of the outlet of one cell as a inlet boundary condition for other cell, this way it would be possible to simulate both.
My question is: how can I do this? How can I export the data from the outlet's (as a function of the flow time/timestep) and import it as a boundary conditions for the same mesh?
Best regards
mcribas is offline   Reply With Quote
Old   July 30, 2014, 12:42
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Well you should be aware of the periodic boundary condition in Fluent, it does excatly what you want.
I also wrote an UDF to perform a similar task (periodicity works two-way, both faces see each-other; mine only one-way, only one face sees the other, which is instead is not aware of the first one), which is here:
http://www.cfd-online.com/Forums/blo...nt-part-4.html
But this is not gonna help unless you have a clear picture of what periodicity is.
sbaffini is offline   Reply With Quote
Export & Import Velocity profile as Inlet eRzBeNgEl STAR-CCM+ 6 March 26, 2012 05:16
STAR-CCM+ import and export not working rks171 STAR-CCM+ 1 December 29, 2011 14:20
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
T-Grid / Gambit import and export Riaan FLUENT 3 January 6, 2006 10:16
Importing I-DEAS unv file hbetb FLUENT 1 August 10, 2001 13:22
