Too long iteration time in parallel processing!
Like Tree2Likes
  • 1 Post By ghost82
  • 1 Post By ghost82
Old   August 2, 2014, 16:27
Default Too long iteration time in parallel processing!
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hi
I need your exprience!
I use fluent 6.3 and I have a 3D domain with 6,500,000 elements!
For my problem, I'm activing energy equ. and k-epsilon model and I'm using air as ideal gas as material!
Note that My domain also have 2 mesh interfaces!
I run fluent as parallel in this system:
Windows 7
Ram 12 Gb
8 parallel CPUs with frequency 2.9 GHz!
When Iterations started, the time for 10 iterations is about 15 mins!
Is this normal?
And is this sentence correct:
"If I increase pc Ram, the solution time will decrease"
Any idea absolutly will be benefit!
Best regards!
amin.z is offline   Reply With Quote
Old   August 4, 2014, 04:00
ghost82's Avatar
Rick
ghost82 will become famous soon enough
How much ram are you using when iterating? Check performances in windows task manager.
ghost82 is offline   Reply With Quote
Old   August 4, 2014, 04:05
amin.z's Avatar
Amin
Hey!
Tnx for your reply!
More than 11.5 Gb
Old   August 4, 2014, 11:37
ghost82's Avatar
Rick
Probably your ram is full and the system is using the swap space on your hdd, which is much slower.
You should increase the total amount of ram.
Daniele
amin.z likes this.
Old   August 4, 2014, 11:51
amin.z's Avatar
Amin
Daniele
Oh! maybe! Probably you're right!
when I tried this mesh with a PC with quad core CPU & 4 Gb ram, I faced "low memory" error!
Do you have any idea to increasing solution time with current computer?
Old   August 4, 2014, 12:28
ghost82's Avatar
Rick
Ram speed and amount is very important in cfd simulations, maybe the most important component.
If your model doesn't fit in the current amount of ram, the only thing to do is to expand it or to decrease the total amount of cells to try to fit the model into your current setup.
Daniele
amin.z likes this.
Old   August 4, 2014, 12:31
amin.z's Avatar
Amin
Dear Daniele!
Thank you very much!
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 11:54
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
interDyMFoam in parallel idefix OpenFOAM Running, Solving & CFD 0 May 21, 2013 03:34
