Fluent-linux: 2 nodes cluster
Old   August 4, 2014, 03:56
Default Fluent-linux: 2 nodes cluster
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi!
I recently configured a windows 2 nodes cluster with infiniband cards and all is working well; however, since I need to run gambit in 64 bits mode, I had to create a linux virtual machine which I think is causing some problems on the ram management.
So I decided to switch to linux.
I successfully installed gambit+fluent 15 in a machine running sles 11 sp2: infiniband drivers are ok and fluent and gambit run ok; compiled udfs are working too.
I'm planning to install fluent on the second node too, in same directory as the first machine.
Firewalls will be disabled, as it's a closed network.
In windows I had to share the working directory: do I have to share that folder in linux too, by exporting the working directory and by running nfs (with same directory structure)?
As I know I have also to create passwordless ssh logins (I think rsh is more difficult to setup).
Other things I have to do to connect the second node?
Thank you
Daniele
ghost82 is offline   Reply With Quote
Linux Fluent HPC parallel system check failed saad3000 FLUENT 1 January 8, 2021 04:34
Fluent in Linux vs. Fluent in Windows Melih FLUENT 6 November 16, 2014 10:39
Fluent MPI process doesn't end in cluster martins ANSYS 0 November 5, 2013 05:18
Which Linux Distro for OpenFOAM and Fluent jason.ryon OpenFOAM 9 December 8, 2010 19:31
Fluent on linux cluster Far FLUENT 0 April 3, 2009 11:03
