April 25, 2011, 04:28 |
Operating Temperature....
VINEETH V K
Rep Power: 15 |
hi,
I am working on a natural convection problem. When my operating temperature was 300 K or less than 300 K, i was getting a convergence of 10^-6 for mass, velocity& energy. But when my operating temperature was changed to above 300 K, say 304 my mass convergence became below 10^-6, where as the other variables are quite alright. I tried several ways( adjusting g, different schemes etc.). still i am not able to get a convergence for mass. can anyone suggest me a method or is it fluents incapability to capture the operating temperature more than 300K. |
April 25, 2011, 06:00 |
Rep Power: 16 |
Hi Vineeth,
is your calculation stationary or instationary? I have made some calculations with temp above 300K and there was no problem occuring Some suggestions: Try Body Force Weighted or PRESTO scheme Instat. calculations are sometimes more stable than stationary ones, so you can try to calculate it instationary. If you are calculating instationary, try to reduce the heat capacity and the density at the wall (try factor 1000) greetings |
April 26, 2011, 00:22 |
VINEETH V K
Rep Power: 15 |
hi sir,
we have tried the schemes. but still we are not able to get the convergence. can you give me some more suggestions. please tell me what is instationary problems. we are in urgent need of a solution for this problem. |
April 26, 2011, 01:36 |
Rep Power: 16 |
I meant that you should try to calculate transient, with a small time step and with a reduced density and heat capacity at the solid body. greetings |
April 28, 2011, 18:13 |
Zi Jian
Rep Power: 15 |
Hi, just one quick question, for solving natural convection, can I just use k-epsilon to solve, instead of using laminar. I find that k-epsilon can converge very fast and the result is reasonable
May 1, 2011, 11:22 |
Rep Power: 16 |
Hello fierceyeo,
it depends whether your case is laminar or turbulent, check your Ra number. greetings |
September 7, 2012, 01:26 |
#7 | |
ethen
Rep Power: 13 |
1.boussineaq, 2 set up thermal expansion index, 3 open gravity model and operation thermal. i have tried the above ways and got a outstanding result. |
September 7, 2012, 05:15 |
#8 | |
Fangdian
Rep Power: 13 |
Which temperature is the operation temperature when i simulate the welding pool (the steel was heated and melt to welding pool) with the boussinesq model? the solidus temperature or the liquidus temperature ? Or i have to set other temperature as the operation temperature? thanks |
September 7, 2012, 07:38 |
#9 | |
ethen
Rep Power: 13 |
September 7, 2012, 16:35 |
#10 | |
Negin Nazarian
Rep Power: 14 |
Im confused about applying your statement to my case. I have a streamwise periodic boundary condition and Im also using solar load model with Do radiation. Im also accounting for buoyancy and used boussinesq approximation. In my case, I defined the operating temperature to be the same as bulk stream temperature that is entering the domain. However, since the solar calculator works with a shading algorithm, the lowest temperature in the domain would be less than bulk stream temperature. (and this is something that I get after simulation) So how should I know that Im putting a correct value as operating temperature and how will it effect my solution??! Should I be concerned? I would appreciate if you advise me on this. Cheers Negin |
September 7, 2012, 20:27 |
#11 | |
ethen
Rep Power: 13 |
so according to this,when i compute my radiation case,always i got an excellence results.plz try again! |
September 7, 2012, 20:48 |
#12 | |
Negin Nazarian
Rep Power: 14 |
initial temperature doesnt have any effect in my case. Im not sure what you are asking me to try right now! Cheers Negin |
August 8, 2014, 10:16 |
#13 |
Joe
Rep Power: 14 |
Negin,
Could you figure it out how to set up the value of the operating temperature? I am working on natural convection...two different temperatures as my BCs(300K and 320K)...using Boussinesq approximation...not sure how to find the correct value of operating temperature... Using 310K to initiate the calculation... Thanks, Hooman |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
average interior temperature less than the operating temperature | Naher | FLUENT | 4 | March 31, 2011 23:14 |
operating temperature for water in porous media | engahmed | FLUENT | 0 | March 3, 2010 16:21 |
Specifying operating temperature in buoyancy flow | PAD | FLUENT | 4 | June 29, 2006 14:44 |
OPERATING TEMPERATURE!!!!!!!!!!!!!! | Anne | FLUENT | 3 | March 28, 2006 04:33 |
