Modeling air flow in Al2O3 melt problem
Old   August 19, 2014, 13:32
Default Modeling air flow in Al2O3 melt problem
Tsaba Nagy
NTSbike is on a distinguished road
Dear everyone!
I need to model the flow of air and molten oxide in an Al2O3-melting furnace. The gas is pushed into the melt on 3.2 bars (in a 6 mm diameter tube) using an "oxidizing pike" which is quite thick compared to the tube. The melt volume is much higher than the oxidizing tube.
The tube is nearly vertical (~12 degrees from vertical) and the gravity's direction is nearly opposite with the gas flow.
As I think, a thinner stream or chanel of air should appear first and farer from the tube, the stream should form into bubbles. Unfortunatley it does not happen. A huge bubble appears in front of the tube and later the melt is pushed out from the furnace. What should be the solution?
The melt is quite viscous (0,04 Pa.s). I turned on surface tension modeling too with constant surface tension.
The air comes in thru a pressure-inlet. There is a pressure-outlet with zero pressure to simulate an open surface. The model is steady with Eulerian multiphase.
Please help.
Thanks
NTSbike is offline   Reply With Quote
bubble, eulerian, melt
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 09:36
Data Center Air conditioning Boundary Condition problem jaypatel OpenFOAM 9 April 8, 2020 15:04
Modeling the air flow of an Internal Combustion Engine mateusdias89 CFX 21 September 23, 2015 08:22
Duct air flow modeling Dan SW FL Main CFD Forum 2 July 6, 2010 04:57
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
