Extracting results on multiple surfaces
Old   October 21, 2018, 11:15
Smile Extracting results on multiple surfaces
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hi All,
I am trying to extract results on multiple surfaces (500+ surfaces). If I name each surfaces during meshing then my solution is taking very long time to converge.
If I name all surfaces together with a single name and separate the surfaces in fluent after convergence, I am unable to save both case and data file, only case file is saving and I am seeing following error in console
Datashipper_insert - normalized key of 852 out of range [0, 99]
How can I resolve the issue since I need all 500+ surfaces for post-processing, I am using CFD-post for postprocessing.
Thank you in advance
Regards,
Sunil
sunilpatil is offline   Reply With Quote
cfdpost, fluent, postprocessing
obtaining transient results from multiple timestep files suyesh FLUENT 1 May 13, 2016 09:52
Problem: Very long "write" time (~2h-3h) for results and transient results Shawn_A CFX 16 April 12, 2016 20:49
[ICEM] Split Block results in not wanted premesh surfaces pizzaspinate ANSYS Meshing & Geometry 0 January 7, 2016 08:12
Using results from experiment studygroups2000 FLUENT 0 November 25, 2015 17:29
Results from multiple processors Radhika Siemens 2 February 11, 2007 23:44
