Single Phase tank drain problem
Old   August 23, 2014, 03:29
Wink Single Phase tank drain problem
careyprice is on a distinguished road
Hi you awesome people, I just started learning fluent and got a few questions about simulating a tank drain process. Any help would be very much appreciated. Thank you!!
The set up is shown in the attachment.
Given:
1. 2 tanks are always filled (always overflowed).
2. Both tanks’ top surface (Red lines, Surface A and Surface B) are free surface and open to atmosphere (1atm)
3. 2 tanks are connected by a tube, which is partially immersed in tank #2.
Objective:
to find the steady state flow speed at the star position.
My questions:
1. How to define BC of A and B?
It seems my system doesn't have any inlet or outlet.....
2. Where should the operating pressure 1atm be defined (A or B)?
From reality, both A and B are at 1atm. However the flow is driven by the liquid pressure, so im confused where to put the operating pressure...
File Type: png Screen Shot 2014-08-23 at 2.22.44 AM.png (62.8 KB, 15 views)
careyprice is offline   Reply With Quote
Old   August 28, 2014, 01:48
Any help please??
Old   August 28, 2014, 05:30
SJSW is on a distinguished road
Originally Posted by careyprice View Post
Any help please??
I think maybe you should try VOF model if you want to observe how the surface change.
SJSW is offline   Reply With Quote
Old   August 28, 2014, 14:42
ghost82's Avatar
Rick
ghost82 will become famous soon enough
If the 2 tanks are always filled (i.e. the level doesn't change) I would set the top level to pressure inlet and the bottom level to pressure outlet (both atmospheric pressure).
For operating pressure take a point inside the domain.
Enable gravity and you should see fluid moving from the top to the bottom.
In your system fluid should enter from A and it should exit to B (so you have an inlet and an outlet).
Daniele
ghost82 is offline   Reply With Quote
coupling vof with single phase flow and gravity term alame005 Main CFD Forum 7 August 6, 2013 12:02
coupling vof with single phase flow and gravity term alame005 Main CFD Forum 0 August 2, 2013 15:37
Unsteady flow - tank drain (please help) Cheese_man Main CFD Forum 0 December 7, 2011 03:08
Two Phase Flow Problem miner15kick CFX 5 October 28, 2010 19:03
Tank problem using CFD meda Main CFD Forum 3 July 1, 1999 22:44
