doubts
Old   August 29, 2014, 06:00
Default doubts
N.Ramchander
ramchander is on a distinguished road
hi i am working on liquid flowing inside the pipe,3-d,laminar and transient type,i want to find the velocity vectors in z-direction,because the flow in z-direction with g value -9.8,i am giving pressure at inlet,can i use ENERGY equation here?generally when we use the energy equation?
and i got velocity magnitude for VECTORS and CONTOURS is different from each other?
is this values from obtained from VECTORS and CONTOURS should be same or not?
and when we use VECTORS and CONTOURS in solution.
pls clarify my doubts.
ramchander is offline   Reply With Quote
Old   August 29, 2014, 15:18
Anonymous
marauder is on a distinguished road
As you seem to be a beginner let's just say that enabling Energy equation let's you define temperatures at your BC and you will be able to do heat transfer problems. Without it I think you are assuming it to be temperature independent.
I cannot understand how you are comparing values in contour and vector plots, these are for representation only.
Take actual values from results tab for comparison.
marauder is offline   Reply With Quote
Old   September 1, 2014, 09:40
N.Ramchander
thanks marauder
simulation doubts pooja_m21 OpenFOAM 1 April 20, 2014 07:28
Some doubts related to fluid mechanics and CFD tulasiram Main CFD Forum 0 March 26, 2013 09:10
Doubts regarding Boundary conditions nova23 FLUENT 1 November 26, 2012 07:25
Doubts about DES simulation L3munoz FLUENT 1 April 1, 2010 11:50
Mesh inflation / Wall condition doubts Kushagra Mittal CFX 2 September 21, 2007 16:34
