Prevent looping in animation
Old   September 5, 2014, 13:41
Default Prevent looping in animation
ansys_matt is on a distinguished road
Does anyone know of a way to use cfd-post for writing an animation movie of fluent data without looping? The quick animation box will let me select the number of loops, unless I want it to loop zero times.
I want the movie to start at timestep 1 and stop at the last timestep. I can't imagine why this wouldn't be allowed, it seems like this behavior would be the default!!
ansys_matt is offline   Reply With Quote
Old   September 6, 2014, 14:51
Strange that this is not possible.
Do you guys use a movie editor to fix the videos you make so they only play from the first timestep to the last? Which editor do you recommend?
Thanks
Old   September 10, 2014, 08:59
Virendrasingh Pawar
virendra_p is on a distinguished road
You can export data into tecplot and animate...i used to do this with c codes but i believe it should work with results ansys as well..good luck!
virendra_p is offline   Reply With Quote
Old   September 10, 2014, 11:03
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Not sure If I really understand the problem.
If you untick the "infinity" button you can enter any number of loops you want.
Choosing 1 does what you described: an animation that starts from the first time step and ends with the last one.
flotus1 is offline   Reply With Quote
Creating animation through TUI wawa FLUENT 35 February 10, 2025 04:31
Animation of Fluent transient data saisanthoshm88 FLUENT 2 December 18, 2012 10:51
Animation of Fluent transient data saisanthoshm88 Tecplot 0 December 16, 2012 10:04
Animation query..newbie qn derick FLUENT 2 December 9, 2005 10:45
Animation in Tecplot ryoga Tecplot 0 February 18, 2002 12:19
