July 11, 2012, 03:55 |
Fire Simulation using fluent
Vignesh V
Rep Power: 13 |
I'm trying to model a fire inside a room of 5*5*5 (m) with a fire source of 0.1*0.1*0.1 m bottom center of the room. how do I simulate the fire to find the heat distribution in the domain. what should be the boundary conditions that I should define. please let me know the procedure. Thanks in advance |
July 11, 2012, 04:03 |
Alex
Rep Power: 46 |
The easiest solution would be to model the fire as an energy source.
July 11, 2012, 08:09 |
Vignesh V
Rep Power: 13 |
Can you elaborate the procedure. |
July 11, 2012, 10:08 |
Alex
Rep Power: 46 |
Am I right assuming that you have very little experience with CFD in general and with Fluent?
In this case, I strongly recommend you do some of the basic tutorials first. I will not explain the whole setup procedure since it would simply take too long and never be complete. The third tutorial Chapter 3: Introduction to Using ANSYS FLUENT: Fluid Flow and Heat Transfer in a Mixing Elbow provides almost all the techniques you need for setting up your case. |
July 12, 2012, 01:26 |
Vignesh V
Rep Power: 13 |
I think my case is different from tutorial which you are describing.
The case is not the mixing of same fluid at different temperatures and to find the heat characteristics of the mixing fluid. My case is related to combustion and species Transport where it can be any two combustive fluid like kerosene-air, diesel-air (as mentioned in Fluent database). I Have created a model and working on it with various B.C's. Till now I couldn't simulate a fire. If I could simulate the profile of fire the temperature of core is same as outside temperature. If I could simulate the temperature the location of the fire is not at the exact location. Find My model in attachments. Please help me in this case. |
July 12, 2012, 02:13 |
Alex
Rep Power: 46 |
So you want to simulate a combustion process?
Sorry but I misunderstood until now. I have no working knowledge about combustion modeling. |
July 12, 2012, 05:30 |
Vignesh V
Rep Power: 13 |
Thank you for your help.
September 12, 2014, 01:39 |
Vishnu C
Rep Power: 12 |
Hi, vignesh did you complete solving it? can you explain briefly if you did it?
Comparison between Solidworks Flow Simulation and Ansys Fluent | Bruce828 | Main CFD Forum | 5 | February 23, 2013 10:13 |
(help) three phase simulation on fluent | sincity | FLUENT | 0 | July 20, 2011 00:19 |
simulation software Fluent. | zerar zahir | FLUENT | 0 | May 29, 2011 13:02 |
FIRE simulation | T.H. Ko | Siemens | 3 | July 24, 2003 23:18 |
Temperature errors on fire simulation? | raymond | Siemens | 0 | January 10, 2002 20:32 |
