Convergence problem
Old   September 12, 2014, 17:38
Default Convergence problem
MarkClarence
Clarence91 is on a distinguished road
Thanks for reading this post.
My problem setup is 3D mesh with sliding mesh motion, transient flow,DPM.
After setting-up all the parameters and run the case, I am not able to get the convergence after few time-steps. Can anyone please help me?
BC for outlet is pressure-outlet. I even decreased the URF of momentum to 0.3 and discrete phase URF to 0.4.
Thnak you.
Clarence91 is offline   Reply With Quote
Old   September 16, 2014, 09:53
Gonzalo
gfoam is on a distinguished road
Hi, I don't understand very well the residuals you posted. First, it seems that you did a steady state simulation, after that you turn on the transient solver and after 900 iterations you get the residuals stabilized? Is that correct? The reasons for you to get divergence may be a lot, but first of all. What is the relative velocity in the sliding mesh, and what is the size of the domain and the relation between size/velocity and the time step are you using? Is it enough to get a good temporary discretization? What Courant number are you using? What schemes of spatial discretization? Well, for now let's check that, then we can see what else we can do. Regards
Gonzalo
gfoam is offline   Reply With Quote
Old   September 16, 2014, 13:08
MarkClarence
For the first I switched-off DPM for the convergence and the rest is with DPM and everything is in transient flow.
I am using 2000RPM for the sliding mesh and the size of the geometry is (10.8*10.4*10.2)cm with inlet (0.6*10.2)
Timestep size is 0.0002, i think this is good for the discretization point of view. I am using a pressure-based solver with SIMPLE spatial discretization method.
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 10:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 04:00
Force can not converge colopolo CFX 13 October 4, 2011 23:03
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 07:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
