"Pressure Gradient p/m" problem in Periodic Boundary Condition |
October 30, 2019, 16:10 |
Rep Power: 9 |
Hi Everyone,
"Pressure Gradient p/m" problem in Periodic Boundary Condition is still a known bug. In version 16, it works. In 17, works. But in 18, it works only for serial process, parallel doesnt work. Is there a way you use to alter this problem? The "Pressure Gradient" shows only 0 "zero" every time. Please see the attached figure. Case file is healty. Partitition method is tried but detailed explanations will be welcomed. Is there a different manual way to make the ansys to calculate this term? Is there a different way to calculate the pressure loss accross the pipe in periodic b.c. method? Thank you |
Speed problem of periodic boundary condition imposed on pitching airfoil. | TG777 | OpenFOAM Running, Solving & CFD | 1 | March 20, 2020 16:33 |
accessing internal cell gradient field at boundary when applying boundary condition | vishalsacharya | OpenFOAM Programming & Development | 7 | February 25, 2019 15:36 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
problem with periodic Boundary condition | amin.z | FLUENT | 2 | December 30, 2014 00:37 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
