ansys fluent modelling
hey, i'm the beginner of ansys fluent and i'm trying to model a fluid flow over a sphere inside a hollow pipe. However, i don't know to separate the fluid flow and the sphere as i can't use the cut material function if i set the solid wall of the pipe and fluid flow as add frozen. Can anyone help in this problem? Thank you:)
you should ask your question in this forum: http://www.cfd-online.com/Forums/ansys-meshing/ Explain your problem, errors and your meshing software there, we will help you! :) |
Ok, i posted at there ady..thx for ur remind:)
