October 7, 2014, 21:04 |
help with pressure gradient force
Jas
Rep Power: 15 |
How to calculate the pressure gradient force of particles in complex and unsteady flow? The internal scheme in fluent is mainly for particles in steady flow. If I use C_P_G directly, it may cause some abnormal results. Until now, I have not found a suitable way to deal with it. Could you give me some suggestions? On the other hand, what's the intrinsic difference between C_P_G and C_P_RG except the using conditions. Thank you! Best regards, socreate |
pressure particle udf |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
how does Fluent calculate the pressure and viscous force vector? | Ralf Schmidt | FLUENT | 2 | May 17, 2010 15:49 |
decreaing pressure force in 2phase model | michaelzhang | FLUENT | 0 | February 26, 2010 08:27 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
