November 13, 2014, 10:13 |
Incorrect Cl and Cd data for a 3D airfoil
raina
I am trying to model a 3D airfoil i.e. an infinite airfoil section to obtain and compare the lift and drag coefficients to that obtained from 2D. In principle, the 2D and 3D data should match. I am under-predicting the lift by ~50% and over-predicting drag by ~60%. I was using a k-w SST model for my simulations.
Given the incorrect results, I went back and simulated the 3D airfoil assuming no viscosity (inviscid solution). But even this solution provides me with a cl that is lower than the viscous experimental data. Any ideas as to what I am doing wrong? I could attach my case files if required. |
November 13, 2014, 12:31 |
B_Kia
Rep Power: 11 |
Did you define the project area correctly ?
November 13, 2014, 14:09 |
raina
yes. I have a 1m chord with a 1m depth.
3d airfoil, drag coefficient, lift coefficient |
