apply positive non-zeropressure boandry conditionwhen using ideal gas law for denisty |
November 14, 2014, 17:19 |
Rep Power: 11 |
hi every one,
what does this message mean in case check before calculating the solution |
November 14, 2014, 20:44 |
Lucky
Rep Power: 65 |
The ideal gas law will be used to compute density from pressure and temperature. Thus, pressure and temperature must be physically realistic quantities. Pressure can't be negative, and temperature can't be less than absolute zero (0 K). Otherwise you can get non-physical densities (like negative density).
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
ideal gas mixing law and mass-weighted mixing law | Shankar | FLUENT | 0 | June 24, 2003 13:25 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
