Dynamic mesh
1 Attachment(s)
Hi, all.
I have here such mesh. Help, please, how to set UDF for rotation of gears? |
Hi Tapoky
I dont know about UDF, but I can recommend you, to use MRF for an steady problem, or to use an Sliding mesh for a transient problem, for more information about this, you can see the fluent user's guide. |
Moving Reference Frame would be indeed perfect for this rather than using dynamic mesh with UDF. If you have the fluent tutorials, there's actually a tutorial for a very similar case, you should check it out. It's called sliding Mesh.
I think mrf cannot be applied because you can't create surfaces of revolution to include the gears without intersecting them. I think the only way is to assign a moving boundary to the gears' walls and set up remeshing. I think there is on ansys support a tutorial for a gear pump, just search for it.
