journal file clarification
Old   November 21, 2014, 05:57
Default journal file clarification
Javi
FJSJ is on a distinguished road
Hi all,
I am trying to create a journal file. I have some questions about it.
Regarding to sequence of commands on the script, do I need to specify the number of iteration before autosave options?
Then, I have the .cas and .dat with the solution initialized. I supposse I donīt have to specify any command regarding to initialization commands because I've already done.
So, with these considerations, the only thing I need to specify is read .cas and .dat files, number of iteration and write .cas and .dat when finished.
It would be something as below:
; Read case and data files
read-case-data example.cas.gz
; Autosave every 1000 iterations
auto-save/data-frequency 1000
; Calculate iterations
iterate 20000
; Write case and data
write-case-data finish.cas.gz
I would like if you can advised in order to clarify those questions.
Thanks!
FJSJ is offline   Reply With Quote
Old   November 22, 2014, 02:49
Lucky
Looks fine.
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
