Fluent running GPGPU throws up divergence error but not in parallel without GPGPU |
December 16, 2014, 02:57 |
I have been using Ansys Fluent 15.0.7 with GPGPU(K20Teslaa Card). Unfortunately whenever I enable GPGPU it is throwing up divergence which is not the case for running parallel sans the GPGPU. My question is it due to GPGPU that divergence is happening due to auto partitioing the mesh? Or is there any other things that I need to do to remove this divergence error. I generally run Fluent in (Parallel-6, GPU-1) mode.
Any help to my problem will be highly appreciated... Thanks in advance........ |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 20:23 |
Problem running a parallel fluent job on local machine via mpd | highhopes | FLUENT | 0 | March 3, 2011 05:07 |
running a journal file in Parallel FLUENT | novice | FLUENT | 0 | June 15, 2010 04:19 |
Parallel speedup Fluent Gigabit Ethernet Myrinet etc | tehache | OpenFOAM Installation | 5 | September 7, 2009 05:51 |
