MRF, 3d Centrufugal Fan Analysis in FLUENT
Like Tree3Likes
  • 1 Post By jpando
  • 1 Post By jpando
  • 1 Post By jpando
Old   December 16, 2014, 13:30
Cool MRF, 3d Centrufugal Fan Analysis in FLUENT
alireza esmaily
kaktus10 is on a distinguished road
Hi Friends
Now i'm working on a centrifugal fan.(same as photos)
I've a lot of questions. i need help.
I know i should use MRF method (and Steady-State), but it doesn't work right (= I can't reach to right solution).
my questions:
1- meshing? (in detail pls.)
2- cell zones? (in detail pls.)
3- boundary area?
4- solution methods?
5-...
however, i tried to solve a 2d,mrf,fan problem, but i couldn't.
kaktus10 is offline   Reply With Quote
Old   December 16, 2014, 16:14
jpando is on a distinguished road
Originally Posted by kaktus10 View Post
Hi Friends
my questions:
3- boundary area?
5-...
First off, MRF is known to be the least accurate method for a fan. It is accepted for general engineering problems and is typically used as the quicked way to get a solution. If you have time, I suggest you use a sliding mesh approach. It is more accurate but you will have to sacrifice more computational time.
2D models are ill-advised unless you have symmetric flow. Even then, they don't always solve correctly.
If you are only looking at the flow, then use a coarse enough mesh to obtain a y+ close to 1 on your fan surface for enhanced wall functions.
kaktus10 likes this.
jpando is offline   Reply With Quote
Old   December 16, 2014, 16:31
alireza esmaily
Now i'm using mrf method.
There is a problem. The interfaces between two zone dosen't work right? What operation should I do?
Thanks
Old   December 16, 2014, 16:57
Thanks
The interface between the zones should be cylindrical. You have the make sure your mesh follows the cylinder surface very closely. Also If the two regions contrain different size cells, there is a maximum ratio of 5:1 for a fluent interface. When you create the interface you also have to select the smaller size surface as your first interface.
Since you are looking for steady state values, you can initialize your sliding mesh with mrf results if you go that route.
Old   December 17, 2014, 00:55
Question
alireza esmaily
Thanks jpando
I'll solve a very simple problem at first. please see my result.
1- what's your mean about ratio? (mesh ratio at interfaces or size of cell zones?)
2- OK -> smaller size is interface1 and bigger is interface2.
3- How can i use the sliding mesh with mrf? (what it means?)
Thanks
Old   December 17, 2014, 00:57
alireza esmaily
In this result ,the dissconection between two zone is very clear.
There is no inlet & outlet. Inner zone has Frame Rotation. Outer zone is stationary area. fluid is Air.
Rotational Velocity is -2500rpm.
Old   December 17, 2014, 01:03
alireza esmaily
Old   December 17, 2014, 05:57
alireza esmaily
alireza esmaily
Please Help
Old   December 17, 2014, 09:39
Unfortunately I am unable to see you pictures. I think it has someting to do with the network I am on.
The ratio I am talking about is the cell size ratio on the surface of the interface. See section 5.4.2. Non-Conformal Interface Algorithm in the fluent user's guide. They give very good details on what is required for an interface.
So the sliding mesh is setup when you have two separate zones. The rotating cell zone is set with frame motion for MRF and mesh motion for sliding. Mesh motion requires a transient calculation to move the mesh. Start off with very small time steps and increase until each time step turns the cell zone about 1 degree (0.017453293 radians). You can increase the step size up to about 2 degrees if the model is behaving well at 1 degree.
From what you are saying,
"In this result ,the dissconection between two zone is very clear.
There is no inlet & outlet. Inner zone has Frame Rotation."
It sounds like the interface is not set as an "interface" in the boundary conditions. I can only guess since I don't see the picture.
Old   December 18, 2014, 09:37
From what I see, the biggest issue is that you are trying to do this problem in 2-dimensions. There is no symmetry in this problem where you can ignore the third dimension. I recommend rebuilding your mesh in 3D and considering all the geometry.
Old   December 22, 2014, 03:11
alireza esmaily
Hi friends,
I solve the problem in 2d and now i'have some problems:
1-At the output in center of the output line there is reverse flow.
2-Flow Rate at the output(outlet) is very low.
3-Flow Rate at the input(inlet) is Zero!!!
photo of solution:
https://www.dropbox.com/s/jfuchg3mqz...sults.PNG?dl=0
Old   December 22, 2014, 03:27
alireza esmaily
ok my friends, i found the problem.
the input velocity magnitude in boundary conditions was zero. Amazing mistake!
how to do analysis for centrifugal air fan using MRF? mrtkrs FLUENT 0 October 13, 2014 04:52
MRF Solver fan simulation - problem sivakumar FLUENT 0 February 15, 2013 04:26
2D Fluent CFD Analysis lamboram FLUENT 0 July 12, 2011 14:02
Fan Modeling in Fluent L. Hamid FLUENT 0 May 24, 2011 03:22
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
