January 29, 2007, 04:47 |
Negative Absolute Pressure
Hi All!
I would like to simulate a system of tundish, slide-gate, submerged-entry nozzle and mould. To whom, who do not know, what this is: This system is used in steel-industry to cast the molden steel into a mould, where the steel solidify. The submerged-entry nozzle (SEN) is mounted under the tundish. Steel runs from the tundish (bath level approx. 1m) thru the SEN in the mould. With the slide-gate you can decrease/increase the area, where the steel runs thru the SEN. This controls the mass flow thru the whole system. My problem: I would like to calculate the mass-flow and the pressure-distribution in dependence of the position of the slide-gate. I used pressure-inlet (gauge-total-pressure 0) and pressure-outlet (gauge-pressure 0) as BC. Operating-pressure is 101300Pa (position at pressure-inlet). I activated gravity. The convergence of the setup is very well, the result for velocity is in a good range. But the pressure-distribution isn`t. I get a negative Abolute-Pressure, which is physically not possible. The Absolute pressure in Fluent (default-setting) is limited to 1Pa. Have anybody an idea, what is wrong with my setup? Thanks in advance, Mike |
December 11, 2014, 04:10 |
negative absolute total and static pressure
Nazim
Rep Power: 12 |
Hello
I am simulating the flow through the perforated gas distributor into the vaccum vessel.I am getting an absolute static pressure and absolute total pressure as negative value at the perforation outlet.Is it possible that we can get negative pressure value??.. |
December 11, 2014, 04:50 |
#3 | |
Rick
Rep Power: 26 |
Google is your friend and the same for the search button! Last edited by ghost82; December 11, 2014 at 09:11. |
December 12, 2014, 00:10 |
Nazim
Rep Power: 12 |
Dear Sir, Your Point is correct there cannot be negative absolute pressure.
But in my case the conditions are typical the Incompressible air is getting exit from atmospheric condition to vaccum condition of 1 pa. i am getting absolute static pressure as negative not the absolute total pressure. so i am still confuse. The flow is getting exit through 10 mm holes there are 16000 holes. |
December 13, 2014, 11:15 |
Lucky
Rep Power: 65 |
I think you are looking at gage pressures and not absolute pressures.
Absolute pressure (whether static or total) cannot be negative. Fluent should have thrown all sorts of errors and applied limiters as soon as it encountered a negative absolute pressure. The default limiter applies a lower limit of 1 Pa to the absolute pressure. There's no way for you to even get a negative absolute pressure unless you changed the limiter. |
December 16, 2014, 21:27 |
#6 | |
Rep Power: 13 |
hello, i wonder where can we change the limiter of the Fluent?
December 17, 2014, 11:35 |
#7 | |
Lucky
Rep Power: 65 |
Solution => Solution Controls => Limits There you can the limiters for minimum and maximum: pressure, temperature, and other turbulence quantities. It is highly recommended that you leave these at their defaults and do not change these from their default values unless you are an expert. The defaults for pressure are min 1 Pa, and max 5e10 Pa. |
December 17, 2014, 20:32 |
#8 | |
Rep Power: 13 |
thank you for your replay. i cannot agree with you more. i just want to see the limits of the pressure and i do not change it. As we see, the minmim value of the absoulte pressure in fluent is 1 Pa, why the absoulte pressre be negative? and the residual of each equation is so small during the iteration
December 18, 2014, 03:50 |
#9 |
Rep Power: 26 |
To be sure: when you say "i am getting absolute static pressure as negative", what exactly is negative in Fluent? The "static pressure" or the "absolute pressure"?
Manifold Absolute Pressure in Engine Simulations | abminternet | OpenFOAM | 4 | July 4, 2011 11:45 |
seeking for help about a room with negative pressure | mengyue1 | FLUENT | 0 | November 26, 2009 06:40 |
negative pressure in cfx | flar.t | CFX | 1 | December 18, 2006 23:20 |
negative static pressure | Selo melo | FLUENT | 5 | December 18, 2006 09:30 |
avoiding negative absolute pressure!!! | Tania | FLUENT | 8 | March 30, 2004 18:41 |
