Home > Forums > FLUENT
Roughness
Old   December 27, 2014, 18:37
Exclamation Roughness
Anwar
4asino is on a distinguished road
In Ansys Fluent, How can i use roughness inside pipe in my setup (also what is the used Model) ?
Secondly, If i want to start roughness after a distance from the inlet of the pipe -not from inlet directly- how can i do that ?
4asino is offline   Reply With Quote
Old   December 28, 2014, 11:49
ghost82's Avatar
Daniele
ghost82 will become famous soon enough
Check options in boundary conditions for all the walls; you can set roughness heigh and roughness constant (these parameters refer to sand grain roughness).
If you want to start roughness after some smooth pipe you need to create 2 different walls and set their roughnesses appropriately.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   December 29, 2014, 21:59
Anwar
All thanks senior member "ghost82" , can i ask you how can i do that step of splitting wall into two walls ?. is it firstly in geometry , also how can i do ?
Thread Tools
Trackbacks are On
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 55 October 24, 2016 11:10
Laminar flow and wall roughness junbbung FLUENT 1 December 2, 2012 06:57
Wall Roughness pmbov FLUENT 2 February 24, 2012 16:54
NACA standart roughness DAK565656 Main CFD Forum 2 August 24, 2005 00:47
Roughness adaptation in CFX 4.4 Bart CFX 1 May 2, 2003 08:32
