January 1, 2015, 03:41 |
problem with multiphase project
Amin
Rep Power: 14 |
hey friends!
I have an unusual problem with my multiphase project! as you see in attached photo, the problem is a bubble column! the air and water enter form top separately ( in the pic, right! ) After air and water were mixed together, based on buoyancy force, water exits from outlet at the bottom (in the pic, left! ) and air exits form side outlets! I'm using eulerian model for multiphase, and neglected heat transfer (energy equation is off!) the gravity direction is to bottom side ( in the pic, left side!) the solution works good at the beginning, but after a while, a large and unreasonable back flow occurs! Almost 3 times the amount of inlet water! In your opinion, what is wrong? thanx in advance! Last edited by amin.z; January 1, 2015 at 07:01. |
January 1, 2015, 10:10 |
B_Kia
Rep Power: 11 |
hi, i dont understand how do they mixed ? from where mixing process starts ?!
January 1, 2015, 14:39 |
Amin
Rep Power: 14 |
January 2, 2015, 03:43 |
B_Kia
Rep Power: 11 |
can you send a photo of the real object or subject you are modelling ? i dont really understand anything of this picture and you know here speaking farsi is prohibited
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 04:03 |
Multiphase phase (gas-solid) flow using Eulerian-Granular medel ( divergence problem) | jessie | FLUENT | 3 | May 29, 2014 11:05 |
[ICEM] Problem while reopening a project | Daniel_Khazaei | ANSYS Meshing & Geometry | 3 | January 23, 2014 07:11 |
Coupled VOF and Multiphase Segregated Flow for a gas bubble problem?? | EnronZhang | STAR-CCM+ | 1 | December 19, 2013 08:41 |
Multiphase Problem | Kelsuis | FLUENT | 3 | January 28, 2010 02:43 |
