October 8, 2007, 01:08 |
Can't open Case and DATA File
I have big problem ,After Run Program it's convergence already, write Case and Data After that can't Open file.
October 8, 2007, 05:51 |
Re: Can't open Case and DATA File
Please check the model
the big problem is : if your model is 3D but u open it by 2D in fluent or opposite. I hope help |
October 9, 2007, 05:05 |
Thanks you for advice : my problem is (Read case and data -define- boundary condition-solve-control-solution)I want to save this setting and I done (File-Write-case and data) After that when open this file it's show
: Error: FLUENT received a fatal signal (SEGMENTATION VIOLATION). Error Object: () Hit return to exit. |
October 11, 2007, 10:43 |
It could be you dont save same name of data file and cas file. Fluent refer to same name for dat and cas file. Next you have to save the cas and dat file in same name. If not, when you try to open the resulat by -->file -->open cas and data--> will error.
Sources are many, because your case already convergen, i elieve you made different case and dat file name. Please correct me if i wrong Best Regards |
October 16, 2007, 05:58 |
Thank you very much Jones for advidce, For my problem (Read-case and data - Set BC - Iteration-Sulution convergence- write case and data(Same name and write binary files was mark) - after that I exit from FLUENT and next time i can't read case and data form this file ... I want to know the meaning of (write binary files) may be it's key word of this problem You think so ?
My English isn't good. Chern |
October 16, 2007, 09:07 |
Binary is just a codex. You will have problems only when trying to move from Windows to Linux. Try to read, only the case file and then the data file.
April 19, 2016, 11:08 |
can not read case and data
#7 | |
ekkachai
Rep Power: 10 |
Error while saving the case and data file | Sri | FLUENT | 6 | September 2, 2015 09:55 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
Initial condition data file from coarse mesh case | Kushagra | FLUENT | 1 | July 25, 2008 21:53 |
Want a case & data file for cavitation modeling | Sajal Sengupta | Main CFD Forum | 1 | February 4, 2007 10:15 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
