July 4, 2001, 13:16 |
Oil-water-gas phase flow with FLUENT
I am doing a project about two phase flow (oil-water-gas) in a hilly terrain pipe. I have some doubt whether the FLUENT can simulate this flow phenomenon or not?
July 5, 2001, 03:22 |
Re: Oil-water-gas phase flow with FLUENT
Normally fluent 6 will perform this kind of simulation. But I do't know for Fluent 5.
July 5, 2001, 04:52 |
You should be a bit more precise with your question to get a usefull answer.
How do you want to treat the water-oil-emulsion. As one fluid or as two fluids which try to separate during the flow? How much gas and in which form (bubbles or dissolved) do you have? |
July 9, 2001, 05:30 |
Isn't this the realm of simultion programs like OLGA2000? Check out:
http://www.OLGA2000.com/ Hope it helps, -Paal |
July 18, 2001, 03:33 |
Dear sir I am MSc student in petroleum engineering at Petroleum University of Technology(P.U.T). I want information about three phase releative permeability and their behavoir in porous media.
your sincerely: samaneh razaghi |
July 18, 2001, 12:19 |
Dear Samaneh This is the wrong forum for trying to get an answer to your question.
There are many books and papers published on this subject. Try the search engine for "relative permeability", or "reservoir engineering". I hope that this is useful. |
January 6, 2015, 03:16 |
frank
Rep Power: 11 |
Hi there
I am working on oil-water-gas flow in steel pipeline. I have some problem with finding flow pattern. is anybody that can help me? I work with fluent 13 and eulerian anf k-e standard condition. I want to receive to oil wetting and decreasing corrosion rate in pipe. thank you |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Simulation of Gas & Solid Phase Reaction in FLUENT | zdz198728 | FLUENT | 1 | March 14, 2011 04:55 |
Lubricant oil, two phase flow | Rikio | CFX | 0 | December 30, 2008 21:08 |
Liquid water, gaseous water and another gas | Andy | FLUENT | 1 | May 22, 2006 08:51 |
