January 26, 2015, 07:25 |
Jet impingement on granular surface
Rep Power: 11 |
Hi everyone,
Does anybody have any experience in simulating jet impingement on a granular bed using Fluent? More specifically I am intrested to know when a high speed jet impinges on a granular surface, how the surface will be eroded and how the particles are moving. The particles are light enough so that the 1-way coupling will provide a suitable results. |
February 2, 2015, 21:59 |
I think its good to use eulerian-granular model for your particle tracking.
February 2, 2015, 23:24 |
Rep Power: 11 |
Dear Amir,
Salam, Thanks for the reply. Do you have any actual experience in this regard? What I am trying to solve is like this: Consider a surface which is covered with small, light particles. Then a jet impinges on the surface. I want to know how much particle mass is in-fluxed due to erosion and how is the interaction of those particle with the flow. Best regards |
February 3, 2015, 02:29 |
Yes, I used this model for erosion modeling.You can use it for your project.
DEM is also another option but requires higher computational cost. |
dpm, granular surface, jet impingement, multi phase, surface erosion |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Jet Impingement Boundary Conditions | heattransfer | FLUENT | 0 | August 17, 2013 09:15 |
help!! water jet impingement heat transfer! | erfan.art | FLUENT | 1 | July 7, 2011 02:40 |
Free Surface Jet Impingement | John | FLUENT | 0 | July 14, 2006 03:45 |
a doubt with jet impingement | G.Balakrishnan | FLUENT | 2 | November 21, 2000 15:17 |
