Erosion of turbulent flow in pipe
Old   September 8, 2015, 10:10
Default Erosion of turbulent flow in pipe
claudy.daniel is on a distinguished road
Hello I am new in fluent. I want to examine the erosion of the pipe due to liquid-solid flow. The mixture of solids and liquid come from the same source that is inserted into the pipe at a certain speed. Volume fraction of solids is more than 15%. The characteristic of the flow is turbulent with Re reaches 300000.
Because I want to see the erosion of the pipe caused by the solid particles, then I use a dense discrete phase model in the Eulerian multiphase model with one Eulerian phase (the liquid) and one discrete phase (the solid particles)
I use a standard k-epsilon viscous models. And the boundaries that I use are velocity inlet, outlet pressure and wall.
Is there anything else I need to consider? I doubt whether the model that I use is correct or not, because I do not get the convergent result.
Thanks
claudy.daniel is offline   Reply With Quote
turbulent pipe flow result validation preetam69 FLUENT 1 February 22, 2018 21:53
Question - pipe flow simulation to generate turbulent inflow conditions Dan1788 Main CFD Forum 2 December 23, 2014 17:50
Simulating turbulent flow in rectangle pipe with rhoPimpleFoam zqlhzx OpenFOAM Running, Solving & CFD 1 January 6, 2014 05:24
Turbulent flow through a pipe with variable inlet velocity lobstar OpenFOAM Running, Solving & CFD 8 March 28, 2012 11:15
Appropriate model for turbulent, steady state pipe elbow flow milos OpenFOAM Running, Solving & CFD 4 July 9, 2009 02:24
