[Sponsors] | |||||
boundary condition at outlet for microchannel flow |
joseph
Rep Power: 12 ![]() |
Hi all, i have just started studying ansys fluent. what i have to find is the pressure drop in a microchannel with a specified velocity inlet and length of pipe. Nothing is known about outlet conditions. the outlet pressure need not be atmospheric. In such a case what should be my outlet boundary condition?
Ethan Doan
Rep Power: 15 ![]() |
you can use pressure outlet condition just set a pressure at the outlet and the inlet with adapt to give you the correct pressure drop.
joseph
thank you for answering....but i didnt get the method clearly. what do you mean by adapt? can you plz be a little more elaborate?
Ethan Doan
Lets say the pressure drop in your system should be x Pa. if you set the outlet to y Pa then the inlet pressure will be equal to x+y Pa. do you get my point?
joseph
thank you very much....since i m interested only in the pressure drop your advice helped me...but for information may i ask is there any method to input the inlet pressure and find the outlet pressure as a result of it?
Ethan Doan
sorry joseph i haven't done anything like that i am not sure if there is a good way. I am thinking you can switch the position of your pressure outlet and velocity inlet where you specify the velocity at the inlet as negitive so it is essentially an outlet and your pressure "outlet" is your inlet.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
| Boundary Condition for reacting species flow at outlet | Astrodan | OpenFOAM Running, Solving & CFD | 0 | September 25, 2014 11:59 |
| pressure outlet boundary condition | hamid_reza | Fluent Multiphase | 1 | September 9, 2014 14:43 |
| outlet boudary condition for a flow in the pipe | Atit | CFX | 2 | November 9, 2004 18:43 |
| Impinging Jet. Outlet Boundary Condition | Vincent | Main CFD Forum | 0 | December 16, 2003 11:49 |
