February 11, 2015, 07:18 |
Extracting forces generated on a surface
Ivan
Rep Power: 11 |
Hi Everyone.
I have attached pictures of my geometry. As the grooves are rotating at a rpm, pressure is generated. I am able to extract the data for the pressure generated by using Surface Integral followed by Facet Average, Pressure(Field Variable). But what if I need to extract the data for the forces generated on the surface of the grooves? Would be it possible? If yes, how should i go about doing it? Thank you in advance! |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
forces on a surface | novice | FLUENT | 0 | January 5, 2010 02:33 |
forces on a surface | novice | FLUENT | 1 | November 21, 2009 17:20 |
Normal - Helical Surface | m. malik | Main CFD Forum | 3 | February 3, 2006 12:56 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
