February 15, 2015, 11:24 |
Temperature restricted to 5000
Tanmay Inamdar
Rep Power: 11 |
I am modelling a 2mm thick pipe carrying water and heat flux incident on it.and temperature on some of the surface faces is above 5000
I created model in ansys modeler using two extrudes one for liquid and a shell for solid pipe.shadow walls get created and is coupled. I think since flux on surface is same and its a steady state temperature of whole outer pipe surface should be same.I can't understand why some cells show such a hogh temperature. |
Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 11:43 |
Soln. for the message: Temperature is limited to 5000 in 24063 cell on zone 2 domin 1 | msasuzan | FLUENT | 2 | February 19, 2015 18:59 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 17:12 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 06:08 |
where is the calculation of the temperature field | Tobi | OpenFOAM | 1 | July 30, 2012 10:40 |
