[Sponsors] | |||||
SHEIKH NASIRUDDIN
Rep Power: 14 ![]() |
Hello friends,
I want to write udf for rms tangential velocity of a flow through pipe and have no primary knowledge about how to write udf. Though fluent has default way to calculate y-rms velocity but this is not coming correct in my case. That is why I want write UDF code for it. Need help. |
Rep Power: 27 ![]() |
Show us your attempts, and we will tell what to improve. That is the best way to learn it.
SHEIKH NASIRUDDIN
Hello pakk,
Thanks for your response. I'm running LES in Ansys 15.0 fluent for studying turbulence of rotating pipe flow. Rotating pipe flow behaves as solid body rotation.Domain is a circular pipe. While plotting RMS profile of y-velocity(tangential), it is showing negative values. How is it possible? RMS negative?? It seems that software is not calculating y-rms quantity because magnitude of y-rms and y-mean velocities are almost looking same. The following parameters are set: 1. Cell zone condition: Frame motion>Rotational axis-Z>Rotational speed in rad/s; 2. Velocity inlet: Vel.specification method=components>Ref. Frame=Rel. to adjacent cell zone>Cord. system=cartesian>z-velocity=0.8m/s> Fluctuating algorithm=Spectral synthesizer>Turb.intensity=5%>Length scale=0.004m; 3. Wall: Moving wall> Rel. to adj. cell zone>Rotational=0 rad/s(because wall is by default rotating as wall is the integral part of frame)> shear condition=no slip; Do you need any other information? Nasiruddin |
If you want to make a UDF, start making a UDF. You should not care (yet) if it works or not, just write down the steps you want the computer to take.
Then show that attempt here, and we will comment on that. |
Anonymous
Rep Power: 13 ![]() |
Take a simple UDF or an example in UDF manual, try to understand it and modify the code slowly to see how it works. Then try to suit to your problem if you encounter any problem post it here. It's much better that way and more people understand code than your problem!
Believe me, I had the experience and learnt it that way. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 10:07 |
| Wind turbine rotation through UDF in FLUENT | Shamoon Jamshed | Fluent UDF and Scheme Programming | 10 | June 25, 2018 13:58 |
| fluent udf, saving data in udf | mohsen zendehbad | Fluent UDF and Scheme Programming | 15 | June 14, 2017 00:23 |
| Making wave udf in fluent | sunggun1212 | Fluent UDF and Scheme Programming | 7 | October 27, 2015 11:52 |
| UDF problem caused by various version of Fluent | Yurong | FLUENT | 3 | January 15, 2006 11:57 |
