Problem with k-epsilon model
I am trying to create a model of gas injection inside chamber. I created first model with Laminar model. Velocity of air acted as suspected. After changing model into k-epsilon (near-wall treatment - enhanced wall treatment + thermal effects) velocity of air radically changed. Velocity is going down to zero very fast. After that i changed back near wall treatment to standard but it helped only a little bit. Medium is air, inlet velocity 10m/s. Output is pressure outlet. Both 0 Pa. Does anyone know how i can fixe my model to get similar velocity distribution in turbulent model? Sorry if my english is bad. Thank You for help Here is laminar model: http://imgbox.com/uayVR7oi k-epsilon with enhanced wall treatment http://imgbox.com/xtEWB6G1 k-epsilon http://imgbox.com/zdGEdpq6 Here is link to my project (in Ansys 14.5) https://dl.dropboxusercontent.com/u/6374861/13.wbpz |
OK i solved the problem. It was density model of air. After coming back to constant everything is normal again.
Does anyone know good density model of air i can use? Still my heat exchange between air and solid is lame. Flow of air with temperature of 9k°C after 600s is rising temperature of aluminium body for only 100°C (from 300°C). Does anyone handled similar problem? |
How anyone can get some help here? >_<
