Problem with k-epsilon model
Old   February 17, 2015, 08:58
Default Problem with k-epsilon model
Dawid
torkness is on a distinguished road
I am trying to create a model of gas injection inside chamber. I created first model with Laminar model. Velocity of air acted as suspected. After changing model into k-epsilon (near-wall treatment - enhanced wall treatment + thermal effects) velocity of air radically changed. Velocity is going down to zero very fast. After that i changed back near wall treatment to standard but it helped only a little bit.
Medium is air, inlet velocity 10m/s. Output is pressure outlet. Both 0 Pa.
Does anyone know how i can fixe my model to get similar velocity distribution in turbulent model?
Sorry if my english is bad. Thank You for help
Here is laminar model:
http://imgbox.com/uayVR7oi
k-epsilon with enhanced wall treatment
http://imgbox.com/xtEWB6G1
k-epsilon
http://imgbox.com/zdGEdpq6
Here is link to my project (in Ansys 14.5)
https://dl.dropboxusercontent.com/u/6374861/13.wbpz
torkness is offline   Reply With Quote
Old   February 18, 2015, 04:47
Dawid
OK i solved the problem. It was density model of air. After coming back to constant everything is normal again.
Does anyone know good density model of air i can use?
Still my heat exchange between air and solid is lame. Flow of air with temperature of 9k°C after 600s is rising temperature of aluminium body for only 100°C (from 300°C).
Does anyone handled similar problem?
Old   February 27, 2015, 02:44
Dawid
How anyone can get some help here? >_<
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 6 November 15, 2017 12:12
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
problem from k epsilon to k omega NJG OpenFOAM Running, Solving & CFD 0 April 15, 2013 08:24
the combustion model problem hanshandiaoke Siemens 0 November 25, 2011 20:37
Converge problem of Mixture Model Jen FLUENT 8 August 17, 2005 18:23
