Home > Forums > FLUENT
initial velocity in dynamic mesh
Old   March 4, 2015, 11:04
Default initial velocity in dynamic mesh
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hi friends!
I'm working on a problem about projectiles moving!
I need a UDF to set mass, inertia and initial velocity of the projectile!
the problem is that I don't find a macro to set the velocity at start time!
Does it need a macro? or it should be set in fluent?
amin.z is offline   Reply With Quote
Old   March 5, 2015, 06:58
ghost82's Avatar
Daniele
ghost82 will become famous soon enough
Hi Amin,
to set mass and inertia you can use DEFINE_SDOF_PROPERTIES.
To set initial velocity you can use DEFINE_CG_MOTION to be applied to rigid bodies.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   March 5, 2015, 12:43
amin.z's Avatar
Amin
Hi Daniele!
tnx! I haven't enough experience in dynamic mesh field!
I was thinking CG-MOTION is for a constant speed and uniform motion!
How can I use this macro for initial velocity? only a value for "vel" argument? what about values of "time" and "dtime"?
Old   March 5, 2015, 13:18
ghost82's Avatar
Daniele
Better explain with an example:
This udf, for example:
# include "udf.h"
# include "dynamesh_tools.h"
DEFINE_CG_MOTION(mymotion, dt, vel, omega, time, dtime)
Thread *t;
face_t f;
vel[0]= 0.1;
vel[1] = 0.0;
vel[2] = 0.0;
sets a constant translational velocity of 0.1 m/s in +x direction.
So, if you apply it to your rigid body at the first time step it will translate with 0.1 m/s velocity.
omega refers to rotational velocity (omega[0], omega[1], omega[2]).
If you want to change velocities with time, then you can use directly 'time' without use the macro CURRENT_TIME.
So if you have a linear increasing velocity you can replace for example in the udf:
vel[0]= 0.1*time;
dtime is the timestep; as 'time' you can use dtime directly into the udf if you need it.
Old   March 5, 2015, 13:30
amin.z's Avatar
Amin
ok!
I need just a constant speed at first time step and want to fluent calculates the speed at final step! so did I just need "vel[0]= 0.1"?
and what about X , Y compnents!?
Old   March 5, 2015, 14:09
ghost82's Avatar
Daniele
Explain better your problem, as I cannot understand why you want a positive velocity only for the first timestep. And after the first one?
Old   March 5, 2015, 14:22
amin.z's Avatar
Amin
yeah! I have a projectile! it's a component of a bigger moving part and released from it! so it has a initial velocity and I want to know what happen for it after a few seconds! it hasn't any internal force! only gravity and drag reduce its speed!
Is it clear dear?
Old   March 5, 2015, 17:13
ghost82's Avatar
Daniele
Can't this be simulated by patching with high pressure and temperature a small space adjacent to the projectile? Then it will be the pressure that will move the projectile, which will move with 6dof (or restricted 6 dof)
Old   March 7, 2015, 02:23
amin.z's Avatar
Amin
I think it maybe causes significant error in simulation! and also will effects on next time steps!
there is a tab as "center of gravity velocity" in dynamic mesh tab! do you know what is this? I've attached a pic from this tab...
Old   March 7, 2015, 05:26
ghost82's Avatar
Daniele
It is the velocity of the center of gravity.
At time 0, your projectile has a defined position and a defined velocity.
For your case before igniting the high pressure and temperature zone, your projectile is at rest, so you can set velocity to 0 m/s.
Moreover you have to set the initial position of the center of gravity.
These values will be automatically updated during the simulation, as your projectile moves.
Old   March 8, 2015, 05:19
amin.z's Avatar
Amin
Ok! so I could use this tab for applying an initial velocity to the projectile! this velocity only use for time 0 and changes during the solution based on the domain conditions! is this correct!?
Old   March 8, 2015, 10:57
ghost82's Avatar
Daniele
Yes, I think so.
Old   March 9, 2015, 02:53
amin.z's Avatar
Amin
Yes, I think so.
hooom! good! tnx friend
Old   September 26, 2015, 06:35
ANDREY GUZUN
AUGUZUN is on a distinguished road
Hello.
Amin, did it helped ? Did you manage to solve your problem?
I have very simular one.
AUGUZUN is offline   Reply With Quote
Thread Tools
Trackbacks are On
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 5 February 19, 2014 05:30
Why RNGkepsilon model gives floating error shipman OpenFOAM Running, Solving & CFD 3 September 7, 2013 08:00
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
