[Sponsors] | |||||
Agung
Rep Power: 12 ![]() |
Dear all,
hey, i have a problem with my project about gas lift injection. My solution cant converged, the residual is increase. I decreased the under relaxation factor (especially for momentum value) after i realized the residual is increased. I also monitor the inlet static pressure, and it seems to be good. My solution is like the below picture, so, my question is, is it okay or not? http://postimg.org/image/iivzck3xl/ I will very appreciate any comment from you guys Thanks and best regards |
Lucky
Rep Power: 68 ![]() ![]() ![]() |
Looks reasonable, as long as you didn't set the urf's to very small values. I would try to return the urf's back to the defaults to see if has any affect.
Agung
Thank you sir, i have increased the URF and nothing happens with the surface monitor, i think the solution has converged. Thanks for you help
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Convergence problem in Fluent for quenching process | kaeran | FLUENT | 4 | December 1, 2014 03:14 |
| Rotate frame reference convergence problem! | wjy-c | CFX | 2 | September 26, 2014 07:03 |
| Centrifugal pump OpenFOAM, convergence problem, ANSA model | RDD | OpenFOAM Running, Solving & CFD | 0 | July 5, 2014 10:12 |
| Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 04:00 |
| Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
