meshing sharp edges
Old   January 26, 2006, 05:00
Default meshing sharp edges
Ralf Schmidt
what case will result in a better mesh: a body with sharp edges or the same body with edges that are blend with a certain radius?
Ralf
Old   January 27, 2006, 04:59
Default Re: meshing sharp edges
Razvan
Blending with a small radius compared to medium cell size is going to give you a good mesh only using structured grid in this area [imagine how it would look a triangular mesh with a local size of ,say 5 mm, on a rounded 120 deg edge with a radius of 5 mm! There will be no more a rounded edge, but a blunt one. So you will have to refine very much the triangular mesh in that region (I say at least 4 cells on the round portion, meaning a local size of 1.25 mm), which will affect also the surrounding mesh (because of the transition needed)].
So, the mesh will not necesarily be worse or better, but surely bigger when using unstructured meshing!
If you are using structured meshing, then rounding the edge will only complicate the mesh, again because of the transition you will have to make towards the surrounding mesh (not to mention the BL, etc.)
It's your choise!
Best whishes, Razvan
Old   April 6, 2015, 09:11
anonymous
Momo38 is on a distinguished road
Hi. I am new to fluent. Just wondering how to consider a mesh is a good mesh.
Thanks
Momo38 is offline   Reply With Quote
how to deal with sharp trailing edges in icem joegi.geo ANSYS Meshing & Geometry 31 March 5, 2018 19:57
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Boundary layer meshing with sharp trailing edges Andrew Berner FLUENT 1 August 28, 2007 17:39
