UDF: Change boundary condition. Velocity inlet to pressure inlet at time "t"
Like Tree7Likes
  • 7 Post By jpina
Old   April 3, 2015, 13:14
Default UDF: Change boundary condition. Velocity inlet to pressure inlet at time "t"
Jordi Pina
jpina is on a distinguished road
Hello!
I'm trying to simulate an injection moulding process. An injection process is defined by two phases:
1) Filling phase: The polymer fills the mould. It is a velocity controlled phase were the inlet flow is fixed and the machine sets the necessary pressure in order to maintain this flow.
2) Packaging phase: Once the cavity is 98% full. The machine switches from velocity control to pressure control, where the cavity is "packed out" at a constant pressure.
I would like to know how could I make an inlet be a velocity or flow inlet from time 0 to time "t" and a pressure inlet after time "t". I guess I should develop a UDF but maybe there's some other way?
I appreciate your help!
jpina is offline   Reply With Quote
Old   April 3, 2015, 17:59
`e`
`e` is on a distinguished road
Velocity inlet and pressure inlet are two distinct inlet conditions. Fluent needs to know to change between these two conditions and a simple DEFINE_PROFILE or UDF wouldn't suffice.
Try running a scheme file every time step (under calculation activities) which makes the switch between velocity to pressure inlet (TUI command) after a certain time (if statement).
`e` is offline   Reply With Quote
Old   April 7, 2015, 14:14
Jordi Pina
Dear `e`,
I've been trying to do what you suggested me.
I created a macro, which changes the inlet_velocity boundary condition to an inlet_pressure condition.
In the calculation activities I set the following command:
*IF,CURRENT_TIME,GT,3,THEN,macro-2,*ENDIF
However, when solving the problem, Fluent says:
*IF,invalid command [*IF]
I will appreciate your help.
Old   April 7, 2015, 18:09
`e`
What is your macro that "changes the inlet_velocity boundary condition to an inlet_pressure condition"? You need to create a scheme file with the relevant TUI commands for changing the inlet velocity boundary to a pressure inlet boundary condition.
Find these TUI commands and then include them in your scheme file with ti-menu-load-string, for example:
(ti-menu-load-string "tui-command-goes-here")
Perhaps if you're unsure of the steps, start with:
1) run the simulation for a few time steps and then change the inlet condition with the GUI (checks if Fluent won't crash from changing this inlet condition)
2) reset and run the simulation for a few time steps and then changing the inlet condition with the TUI
3) write a scheme file (using ti-menu-load-string) with the commands you used in step 2) and then run this scheme file after a number of time steps (if statement)
Old   April 9, 2015, 10:17
Jordi Pina
Dear `e`,
I'm afraid I need a little bit of help.
I have succeeded on changing the boundary condition from velocity to pressure:
define/boundary-conditions/zone-type inlet pressure_inlet
However, I don't know how to make a line for setting the pressure. If I make
define/boundary-conditions/pressure-inlet
I can set the pressure when fluent asks for it, but it is now suitable for making a .scm...
Thanks!!!!!!
Old   April 9, 2015, 11:33
Jordi Pina
I just found the solution, in case anyone needs it, it's:
Define/boundary-conditions pressure-inlet inlet mixture yes no 6000000 no 0 no 300 no yes
Where the answers to the questions without commas must be written.
Old   April 9, 2015, 16:28
Jordi Pina
I'm facing the following problem... I have created a .scm file with:
*if,CURRENT_TIME,gt,3,then
;Change inlet boundary condition
(ti-menu-load-string "define/boundary-conditions/zone-type inlet_velocity pressure-inlet")
;Set the pressure of the inlet boundary condition
(ti-menu-load-string "define/boundary-conditions pressure-inlet inlet_velocity mixture yes no 6000000 no 0 no 300 no yes")
*endif
However, something seems to happen with the if statement. When I do File-Read-Scheme Fluent says:
Error: eval: unbound variable
Error Object: *if
#f
The same scheme file without the if works.
Does anybody know what is happening?
Thanks!
Old   April 9, 2015, 17:25
Andrew Kokemoor
Kokemoor is on a distinguished road
The correct syntax for if is
(if conditional-statement then-statement else-statement)
so you'll need something like
(if (> current_time 3) (
I'm sure you could clean this up into one if statement, but I'm not in a position to test anything fancy right now.
If I was, though... this is what I'd try.
(if (> current_time 3) (map ti-menu-load-string '("define/boundary-conditions/zone-type inlet_velocity pressure-inlet" "define/boundary-conditions pressure-inlet inlet_velocity mixture yes no 6000000 no 0 no 300 no yes")))
Kokemoor is offline   Reply With Quote
Old   April 10, 2015, 02:33
Jordi Pina
Dear Kokemoor,
first of all thanks for your help.
I'm afraid to ask an obviety but... In which programming language is the code you typed?
I had looked for distinct APDL manuals and none of them showed this 'if statement' structure, for example the manual https://caeai.com/sites/default/files/APDL_0.pdf shows an estructure like:
*IF, VAL1, Oper1, VAL2, AND / OR, VAL3, Oper2, VAL4, THEN
Your code is not C either :S
Old   April 10, 2015, 06:34
`e`
We've both stated that you're creating a Scheme file: the programming language is Scheme (a dialect of LISP). LISP is the second oldest high-level programming language (second to Fortran), have a read of the Wikipedia article if you're interested. Scheme was created in the 1970s over in MIT (Wikipedia). I'll quote what I've typed in another thread:
Originally Posted by `e` View Post
Fluent has no official documentation for Scheme, and in fact the developers were intending to replace Scheme with Python as the official scripting language back in 2004... have a read of this unofficial Fluent Scheme Programming Reference which I believe is the only Scheme-Fluent documentation available.
Old   April 11, 2015, 14:19
Jordi Pina
Hi everybody!
I've solved my problem, I expose here the definitive solution in case it's someday useful for somebody:
For changing a boundary condition at a time t:
Create a .scm file with the following content:
(if (> (rpgetvar' flow-time) 0.05)
; Set que inlet_velocity boundary to pressure-inlet
; Set the pressure value to 6000000
In the Calculation Activities make this scheme file be executed every time_step with:
(load "velocity_to_pressure_inlet.scm")
I hope to be helpful after all the received help
change, inlet pressure, inlet velocity, udf
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 21:18
can i set the velocity and pressure at the inlet at the same time by UDF minyang.cau FLUENT 0 July 14, 2009 23:14
