How can i get velocity profile like this ?
Like Tree15Likes
Old   April 13, 2015, 12:32
Falcon35 is on a distinguished road
Originally Posted by CeesH View Post
I just looked at the Cornell results, and they do see the same overshoot in velocity at the edge of the boundary layer there. With that, I assume there is a small y-velocity component as well. Because in your case, it is there in the solution. If you color by the y-velocity instead of x-velocity, you'll see.
how can i fix it ?
Falcon35 is offline   Reply With Quote
Old   April 13, 2015, 12:37
Cees Haringa
CeesH is on a distinguished road
Well, if they find it as well, with the current fix there may not be a fix. Perhaps with a more refined mesh, and stricter residuals you do get closer to the Blasius solution. But if you are doing the exact Cornell tutorial, this is probably what it is.
CeesH is offline   Reply With Quote
Old   April 13, 2015, 12:41
so is it true or false ? and how can i get location of 0,99*Uinlet ?
Old   April 13, 2015, 12:52
Cees Haringa
Physically, it should not be there. Numerically, it is, and it also is in the tutorial. If your goal is to replicate the tutorial, I wouldn't worry about the result. Otherwise, see if increasing mesh density helps.
Old   April 13, 2015, 12:57
man, i won't replicate , i have to do my homework and i need location of 0,99Uinlet to calculate boundary layer thickness numerically please help me ?
Old   April 13, 2015, 13:01
Cees Haringa
increase the mesh density, see if the results change. To get the 0.99-level; with umean is 1, plot the iso-surface where u is 0.99m/s
Falcon35 likes this.
Old   April 13, 2015, 13:05
okay good, how will i do it for 0,99Uinlet ? Can you describe it step by step like this plot>area-weighted average vs vs (for example) again ?
Old   April 13, 2015, 13:15
Cees Haringa
In FLUENT, you could create a custom field function: define > custom field function. Set this equal to Ux/<enter value of inlet velocity>.
Then go to surfaces > iso-surface, and create an iso surface of constant field function, value 0.99.
Next, go to graphics and animations, contours and plot the surface.
This gives you a qualitative view however. For a quantitative view, I would recommend exporting the data to MATLAB or CFD post. Maybe it's possible in FLUENT too, but I don't know how to do that for every x-location. Perhaps you should also take a look at the post-processing part of the cornell tutorial because they explain the steps for plotting in CFD post very clearly, also normalization, and with that you should be able to do it.
Old   April 13, 2015, 14:13
May i do it by "write to file" velocity profile for every x ?
Old   April 13, 2015, 17:55
brother ????
Old   April 14, 2015, 03:53
Cees Haringa
You can use write to file for every desired x indeed; then import the data into excel, matlab or some other software, and do the quantitative analysis there.
Old   April 14, 2015, 04:48
May i see boundary layer thickness in there by 0.99U ?
Old   April 14, 2015, 04:59
Cees Haringa
yes. when you have the numbers, for each value of x you can look up the first number where Ulayer > 0.99U. Write down the position of this value for each x-position, and you get a good view of the boundary layer development
Old   April 14, 2015, 05:47
ty, i got 0,025 m boundary layer thickness for x= 0,5 m but i got it 0,034 by analitical method why is it ?
Old   April 14, 2015, 05:54
Cees Haringa
Neither. Both the analytic and numerical approach make assumptions and thereby are approximate. Compare both with experimental data, and see which gets closer.
Old   April 14, 2015, 06:02
how can i compare both with experimental data
Old   April 14, 2015, 06:37
Cees Haringa
You need to find a source reporting experimental data regarding boundary layer development over a flat plate. It must exist, because solutions like the Blasius solution are developed based on and compared to such data. Look in literature, find the data, do the comparison.
Old   April 14, 2015, 06:50
But teacher wanted us to calculate it by formula and ansys fluent ? i asked you why are they too different ; fluent's value 0,025 , formula's value 0,034 ?
Old   April 14, 2015, 07:03
Cees Haringa
As I said, both the numerical approximation and the analytic solution make certain assumptions which cause their solution to differ. study the assumptions you make in both approaches, compare what their effect on the found profile might be. But remember, neither approach gives a perfect answer.
Old   April 14, 2015, 07:18
then different results between 0,025 and 0,034 NORMAL ?
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 03:44
[swak4Foam] Inlet velocity profile for turbulent pipe flow using swak4Foam zordiack OpenFOAM Community Contributions 5 February 23, 2016 01:52
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 19:09
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 17, 2009 23:36
Prescribed inflow velocity profile - how to? Alan Main CFD Forum 10 October 28, 2005 12:14
