How can i get velocity profile like this ?
Like Tree15Likes
Old   April 13, 2015, 10:06
Default How can i get velocity profile like this ?
Falcon35 is on a distinguished road
How can i get velocity profile on a flat plate with FLUENT like this ?
Falcon35 is offline   Reply With Quote
Old   April 13, 2015, 10:43
Cees Haringa
CeesH is on a distinguished road
LIke mentioned before, set up lines normal to the surface at the locations you want to plot, and plot the x-velocity vectors on those lines
Cheers,
Cees
Falcon35 likes this.
CeesH is offline   Reply With Quote
Old   April 13, 2015, 10:50
Cheers,
Cees
i did it but i get this nonsense thing ? :/
Old   April 13, 2015, 10:58
Cees Haringa
well, I wouldn't worry too much about the plot itself. more about your results; why is there a peak in your velocity profile? Discretization schemes maybe?
Regarding the plot, you apperantly want a vector plot rather than an x-y plot. That can be done. Use graphics and animations > vectors rather than reports > plot. Think about the length of your line too, because you now plot a large part of the bulk which compresses the boundary layer. Doesn't mean the plot is wrong, but it compromises clarity.
Old   April 13, 2015, 11:07
i got this now , what didn't happen again ?
Old   April 13, 2015, 11:09
Cees Haringa
that's a contour plot. Not a vector plot. Also, this is on the whole body, not just on the lines you made.
Old   April 13, 2015, 11:11
then how can i do it vector plot ? i pushed vector plot ?
Old   April 13, 2015, 11:13
Cees Haringa
graphics and animations menu, option 3 is 'vectors'. Click this one, and select the created lines as plot regions
Old   April 13, 2015, 11:19
okay i got it now how can i zoom it ? i pushed zoom button but it doesn't work, plot seems so small so how can i got 0,99 Uinlet velocity from this plot ?
Old   April 13, 2015, 11:21
Cees Haringa
You can't zoom in. What you can do is make new lines, which have a short y-component - close to what you expect the boundary layers to be.
Edit: sorry, of course you can zoom in using the zoom tool in the top menu. My bad.
Old   April 13, 2015, 11:31
i got it and someone got it why ?
Old   April 13, 2015, 11:35
Cees Haringa
because you are plotting over the whole domain height. You need to make a line that doesn't extend all the way from top to bottom, but instead only to say, Y = 2D where D is the estimated boundary layer thickness.
Old   April 13, 2015, 11:41
then which type line should i plot ? i plotted from bottom to top ?
Old   April 13, 2015, 11:43
Cees Haringa
make a new line/rake, and enter the x and y coordinates you want.
for x, maybe you want L/2 again?
for y, take 0 to some that is more in line with the size of the boundary layer. Maybe something like H/10, where H is the total height in the y-direction
Old   April 13, 2015, 11:50
i did it and i got it this time ...
Why couldn't i get this again ?
Old   April 13, 2015, 11:54
Cees Haringa
If you use the + button on the screen now to zoom your view?
click on the zoom icon, and draw a box around the profile you made.
(sorry, when I said 'you can't zoom' before, I meant you cannot plot only the boundary layer piece. of course you can still zoom the view; my mistake)
Falcon35 and Togenar like this.
Old   April 13, 2015, 11:59
thank you but why aren't they STRAIGHT ? o.O
Old   April 13, 2015, 12:16
Cees Haringa
Unfortunately, that's not a plotting question. It seems there is a y-component in your velocity as well (of course, you can check this) - and the vector direction is based on the velocity direction. This also causes a local maximum at the edge of your boundary layer. So there seems to be an error in your simulation. Do you use laminar or turbulent flow (and what is your reynolds number?) Did the simulation converge? Which momentum discretization scheme did you use?
Old   April 13, 2015, 12:22
i have only x velocity of 1 m/s , my Re number 1000 and yes it's same a tutorial from cornell university, it converged why did happen it ?
Old   April 13, 2015, 12:30
Cees Haringa
I just looked at the Cornell results, and they do see the same overshoot in velocity at the edge of the boundary layer there. With that, I assume there is a small y-velocity component as well. Because in your case, it is there in the solution. If you color by the y-velocity instead of x-velocity, you'll see.
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 03:44
[swak4Foam] Inlet velocity profile for turbulent pipe flow using swak4Foam zordiack OpenFOAM Community Contributions 5 February 23, 2016 01:52
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 19:09
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 17, 2009 23:36
Prescribed inflow velocity profile - how to? Alan Main CFD Forum 10 October 28, 2005 12:14
