how to determine the C0 and C1 on interior wall in fluent UDF
Like Tree2Likes
  • 1 Post By A CFD free user
  • 1 Post By pakk
Old   April 14, 2015, 03:04
Default how to determine the C0 and C1 on interior wall in fluent UDF
zhouxman
zhouxman is on a distinguished road
Hi,everybody,
how to determine the C0 and C1 on interior wall in fluent UDF?
zhouxman is offline   Reply With Quote
Old   April 15, 2015, 17:39
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Originally Posted by zhouxman View Post
Hi,everybody,
Dear Friend,
c0 = F_C0(f,t) and c1 = F_C1(f,t) are actually two macros are used to access to adjacent cell thread for faces (walls or interior). For wall faces, only c0 is available; however, for interior faces both c0 and c1 can be accessed via the right-hand rule. To determine the c0 and c1 thread on interior faces, you need to find the area normal vector. The cells out of which the area normal vector is pointing to is defined as c0 thread and the ones into which the area normal vector is pointing to is called c1 thread. So to get the right c0 and c1, first you should get the pertinent face thread using face look_up macro ant then employ the right-hand rue. To make it clear, see the schematic in attachment.
I hope it helps
Vicky3141 likes this.
Regard yours
A CFD free user is offline   Reply With Quote
Old   April 15, 2015, 21:12
zhouxman
Originally Posted by A CFD free user View Post
Dear Friend,
I hope it helps
dear,
thanks for your reply!
as show in your schematic , is it means the c0 and c1 are fixed as shown in your schematic? how about the THREAD_T0 and THREAD_T1 ?
best regard
Old   April 17, 2015, 03:35
Default how to determine the 'area normal vector'
zhouxman
Dear Friend,
I hope it helps
dear,
Old   April 17, 2015, 03:45
pakk will become famous soon enough
To answer your question, it would help what you mean with "determine".
Do you want to know how to calculate the area normal vector in a script?
Or do you want to know what "area normal vector" means?
Or something else?
pakk is offline   Reply With Quote
Old   April 18, 2015, 06:32
Default Dear pakk,
zhouxman
Or something else?
Dear pakk,
I want to know how to calculate the area normal vector in a script and the means of "area normal vector" .
Thanks
Old   April 20, 2015, 02:57
Probably the words "area normal vector" did not appear out of nowhere into your brain. You must have read it somewhere.
In fact, the only place I know where these words are used is in the Fluent manual. So I suggest you look there.
Old   April 26, 2018, 10:11
Default THREAD_SHADOW(t) flluent udf
Morteza
Morteza60 is on a distinguished road
Hello all
I would like to know what is the functionality of THREAD_SHADOW(t) macro? I have searched little bit but i did not find any useful information. Can anybody demonstrate above macro in a UDF?
Morteza60 is offline   Reply With Quote
Old   April 26, 2018, 10:18
If you have a shadow wall in your simulation (an internal interface between a solid volume and a fluid volume), then in Fluent's internal storage, these are to boundaries:
* The solid-to-fluid boundary, as seen from the solid
* The fluid-to-solid boundary, as seen from the fluid
If, in a UDF, face thread "ft" refers to a solid-to-fluid boundary, then THREAD_SHADOW(ft) refers to the corresponding fluid-to-solid boundary.
If, in a UDF, face thread "ft" refers to a fluid-to-solid boundary, then THREAD_SHADOW(ft) refers to the corresponding solid-to-fluid boundary.
If, in a UDF, face thread "ft" does not refer to one of these two boundaries, then THREAD_SHADOW(ft) is NULL.
Mohamed Mousa likes this.
Old   April 26, 2018, 16:51
Morteza
Thank you very much pakk
Could you please make an example of fluid-solid domain? the solid domain should be part of simulation and don't necessary have to be a wall. am I right?
like gas in vicinity of porous media?
Old   September 1, 2019, 08:36
Default Determine F_C0 and F_C1 on an interior wall
  #11
Jason FANG
Jasonf is on a distinguished road
Hi everyone!
I am also wondering how to determine the macros of adjacent cells, F_C0 and F_C1, on an interior wall (interface between fluid and solid zones) as illustrated in Fig. I heard of the right-hand law, but I do not know how to use it. Is there any simple way to solve this problem?
Thanks for any help!
Jasonf is offline   Reply With Quote
