April 15, 2015, 08:18 |
Mesh sizing on a flat plate ?
Rep Power: 11 |
Hi friends,
i have a question about fluent, which meshing size should i use on a flat plate to calculate bounrdary layer thickness for x = 5 m , y = 7,9m ? |
April 16, 2015, 03:32 |
Rep Power: 18 |
Start with a coarse mesh but resolve the near wall region (where you expect the boundary layer to appear). You could either use inflation layers or edge sizing to increase the mesh resolution near the wall. Then perform a mesh independence analysis by refining your mesh and comparing the results of your boundary layer velocity profile to your coarse mesh. Repeat these steps until you reach a converged solution.
High aspect ratio mesh problem for flat plate boundary layer | sam1364 | OpenFOAM | 3 | May 14, 2020 11:11 |
k-omega-SST model (OF 1.6) - turbulent flat plate | cboss | OpenFOAM Running, Solving & CFD | 25 | August 9, 2016 09:53 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
Refined mesh for flat plate | StarCD | Siemens | 0 | May 31, 2004 10:52 |
