shell conduction model
hey friend
can shell conduction model be used in parallel mode!? |
Yes, I think so..I used it for the computation of a tube in tube heat exchanger without problems..why this question? Did you read somewhere that it cannot be used in parallel?
When I used parallel setup, fluent said fatal error and crashed! but when run on serial setup it works very well!
I've checked several settings but haven't succeed... |
Ok, the error should be related to something else, not to shell conduction/parallel calculation.
Did you try to disable shell conduction and run in parallel?Did you get the same error? If you want to share the cas I can try to run it on my pc to see if the error is due to ansys installation..you have my email. Daniele |
Tnx friend!
ya, it's working normally without shell conduction in parallel mode, I'm performing some modification in the model for new run, if the problem doesn't solved, I will share it with you tnx for your kindness support |
