April 16, 2015, 01:28 |
shell conduction model
Amin
Rep Power: 14 |
hey friend
can shell conduction model be used in parallel mode!? |
April 16, 2015, 16:24 |
Rick
Rep Power: 26 |
Yes, I think so..I used it for the computation of a tube in tube heat exchanger without problems..why this question? Did you read somewhere that it cannot be used in parallel?
Google is your friend and the same for the search button! |
April 18, 2015, 03:23 |
Amin
Rep Power: 14 |
When I used parallel setup, fluent said fatal error and crashed! but when run on serial setup it works very well!
I've checked several settings but haven't succeed... |
April 18, 2015, 09:49 |
Rick
Rep Power: 26 |
Ok, the error should be related to something else, not to shell conduction/parallel calculation.
Did you try to disable shell conduction and run in parallel?Did you get the same error? If you want to share the cas I can try to run it on my pc to see if the error is due to ansys installation..you have my email. Daniele
April 18, 2015, 09:52 |
Amin
Rep Power: 14 |
Tnx friend!
ya, it's working normally without shell conduction in parallel mode, I'm performing some modification in the model for new run, if the problem doesn't solved, I will share it with you tnx for your kindness support |
Shell Knock model for NG combustion | cfdvenkatesh | AVL FIRE | 0 | June 24, 2014 19:11 |
shell conduction (urgent) | muhittin | FLUENT | 4 | September 24, 2013 03:30 |
coupled field in shell model analysis | chenwen521 | ANSYS | 0 | September 28, 2009 22:32 |
Shell Ignition Model | Felix | Main CFD Forum | 0 | February 10, 2006 00:40 |
Shell conduction and Conjugate problem | RBM | FLUENT | 1 | October 24, 2005 12:20 |
