May 4, 2015, 05:53 |
Problem with auto-generated interfaces
Thomas MADELEINE
Rep Power: 11 |
Hi every one !
Sorry to disturb you on something that simple, I am quite new on Fluent. I have a model with small tubes quite close to each other in order to catch the vorticity inside my geometry (I calculate the torque on these tubes). When I open Fluent, the software is creating a lot of interfaces between some tubes walls (I have 100 tubes and he creates like 30 interfaces). Note: I am using WorkBench and ANSYS Meshing, I have created Named surfaces for every thing. The problem is, I have to delete these one by one and change the property to wall one by one too. Quite long procedure. So I wanted to know if there is such an option to deactivate the auto-generating interface or to set the precision gap (when Fluent will consider that two surfaces are an interface) Sorry for my bad English and thanks you all for your attention. Thomas |
May 7, 2015, 03:29 |
Paritosh Vasava
Rep Power: 22 |
Hello Thomas!!
You can delete the unwanted/extra interfaces in Ansys meshing itself. It will save you a lot of time while setting up case in fluent. |
May 7, 2015, 03:46 |
Thomas MADELEINE
Rep Power: 11 |
Hi Vasava,
Thanks a lot for your help. It is the connection stuff in the ANSYS Meshing, isn't it ? |
May 7, 2015, 04:52 |
Paritosh Vasava
Rep Power: 22 |
yes it is. You can simply click on the interface title and the interface faces will be highlighted (all the other boundaries will turn transparent).
Also in the details you can check the number of faces etc. In case the interface is not set correctly you can correct it manually. |
May 7, 2015, 05:10 |
Thomas MADELEINE
Rep Power: 11 |
thank you a lot ! I deleted it and it worked perfectly !
I will take a closer look next time on ANSYS Meshing before closing it to import in Fluent ^^ |
[OpenFOAM] paraview 3.8 auto rescale doesn't work | JDR | ParaView | 18 | September 14, 2013 15:15 |
Problem with Automatic Default Interfaces | jehan | CFX | 1 | June 15, 2010 10:11 |
Velocity profiles problem behind the elbow (3D problem) | kabat73 | FLUENT | 8 | May 9, 2010 04:26 |
Multiple Sahdows / Periodicity Problem | Michael Pi | FLUENT | 0 | July 11, 2005 07:42 |
asymmetric solution generated by symmetric problem | Twiti | CFX | 7 | October 16, 2004 19:12 |
